Reading data from textfile into macro
I wish to read some parameters from a text file and use it to assign values in a starccm macro. The code looks something like this: java.io.FileReader freader = new java.io.FileReader("pathToFile"); java.io.BufferedReader inputFile=new java.io.BufferedReader(freader); //courseName=inputFile.readLine(); while ((line=inputFile.readLine())!= null) { String[] arrayline = line.split("\\s+"); data[i] = Double.parseDouble(arrayline[1]); } inputFile.close(); R = data[0]; L = data[1]; r = data[2]; l = data[3]; angle = data[4]; I'm getting a error:unreported exception, java.io.FileNotFoundException; must be caught or declared to be thrown. I'm not too familiar with java, but still have tried all possible suggestions given in java forums. I'm not sure if the issue is related to how java scripts work in StarCCM. It would be great help if someone can help me out ! |
You are not telling Java what to do in case the file you specify doesn't exist.
https://examples.javacodegeeks.com/j...und-exception/ |
