December 13, 2016, 03:03 |
Solver for isochoric process
Rep Power: 9 |
I am simulating an isochoric process: - Closed Cube (4 wall boundaries, as I am doing a 2D-simulation) - Gas (Air) filled - Heated by the walls from 300 K to 400 K - No velocity profile, only natural convection For this case, the volume and the mass is constant. Therefore, the average density in the cube is constant. Because of the Ideal Gas Law, the pressure should rise with the temperature rise of the gas. But in my simulation, only the density changes (which is physically total wrong), but the pressure stays almost constant. Also, if I change the thermal conductivity of the gas, the value of the pressure at the end of the simulation is completely different, which is totally wrong. Thermal conductivity only affects, "how fast" heat is transferred trough the gas, but does not affect the pressure level at the end of the simulation. This all happened, while I was using the Coupled Solver. Yesterday I switched to the Segregated Solver and now everything is fine. All of the problems from above are fixed and the pressure rise is corresponding to p2/p1 = T2/T1 (Ideal Gas law for an isochoric process), while the average density in the volume is constant. Did I find a bug in the coupled solver? Because I think, the different solvers only change the way, how the equations are solved, but should not effect the results on the whole (especially not in that extreme way, it does here). Best regards Last edited by simulant1; December 13, 2016 at 04:18. |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Some notes on Creational Process of an OpenFOAM solver | jaswi | OpenFOAM Running, Solving & CFD | 1 | August 30, 2010 11:49 |
Automating Solver Process | KUAERO | Fluent UDF and Scheme Programming | 3 | July 24, 2010 04:16 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
