Automatically applied heat flux due to species flux
Old   November 17, 2021, 10:12
Default Automatically applied heat flux due to species flux
FliegenderZirkus is on a distinguished road
The species solver supports three types of boundary conditions, here's a table from the manual:
Table 31: Properties of the Wall Species Option
  1. Impermeable: Specifies the boundary as impermeable.
  2. Specified Flux: Specifies a species flux at the boundary. The energy that is associated with the wall species influx or outflux is appropriately added.
  3. Specified Value: Specifies a species mass fraction at the boundary.
I'd like to ask how the highlighted energy is calculated and what is the physical reasoning behind such a heat source/sink. I'm trying to model evaporation and am applying the latent heat of evaporation as heat flux profile, but this automatic heat due to species flux at a boundary seems to be superimposed to what I prescribe. To reproduce this just prescribe a species flux at a boundary and plot the boundary heat flux on the same boundary. The energy solver must be switched on. Thanks for any clues!
FliegenderZirkus is offline   Reply With Quote
Old   November 19, 2021, 06:08
Joern Beilke
JBeilke is on a distinguished road
When you remove a species ( for instance 10 droplets of water) at the wall, then you also loose the energy of the removed species in your flow domain.
JBeilke is offline   Reply With Quote
Old   November 19, 2021, 08:49
Would you say it's the enthalpy then, as in \dot{Q} = \sum _i \dot{m}_i \cdot c_{p,i} \cdot \Delta T, whre i are all species? What would be the reference temperature though, 0 Kelvin? I also noticed there's a field function called ThermalDiffusionFluxEnergySource but I couldn't find any documentation on it.
Old   November 22, 2021, 10:53
Joern Beilke
This look right. I expect, that ccm+ does this calculation automatically.
diffusion, heat flux, species
Heat Flux due to electron flow in GTAW welding process redwanamit034 FLUENT 0 August 11, 2017 17:26
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
UDF for heat flux applied during T seconds nazeem FLUENT 0 June 22, 2004 05:26
UDF for a heat flux applied during T second on a w nazeem FLUENT 0 June 12, 2004 10:28
