February 14, 2017, 16:10 |
Simple two-parallel disc analysis
Saima
Rep Power: 16 |
Hello All,
I am doing compressible, turbulent two parallel disc analysis. Flow is entering from small radius and out from larger radius. Now I just know inlet conditions, I don't know the outlet pressure. How to specify it? Thank you,
Best Redards, Saima |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Simple Serial to Parallel UDF conversion Fluent | amir00251 | Fluent UDF and Scheme Programming | 2 | September 1, 2015 04:32 |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 13:44 |
Buckling analysis of a simple plane truss | george85 | ANSYS | 3 | March 12, 2013 06:56 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
