March 14, 2017, 00:13 |
Compressible Pipe Flow
U.S
Rep Power: 10 |
Hello dear friends,
I am a newbie in StarCCM+ and trying to simulate an air pipe flow. My input is mass flow rate, like a normal pipe flow. In my simulation I am trying to see the heat transfer. The pressure of the air is around 10 bars. Therefore, I am not sure which models to use. I tried: -steady -3d -gas -segregated flow -ideal gas -segregated fluid temp. -turbulent -k-epsilon however my solution did not converge. Could you guys suggest me any physics models if you have any experience ? Kind regards, |
March 14, 2017, 01:32 |
#2 | |
Lane Carasik
Rep Power: 14 |
March 14, 2017, 05:39 |
U.S
Rep Power: 10 |
Mesh is like the following. I used: Generalized cylinder, exturuder, prism layer(2 layerS) polyhedrad mesher and surface remesher. I estimated a y+, but could not check it. Convergence problem i defined as : divergence at the second step(floating point problem it says) Thanks for the reply btw |
March 14, 2017, 09:37 |
Rep Power: 24 |
Make sure you are setting your reference pressure to 10 bar and the outlet to 0.
Display Modes | |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 07:59 |
Pipe flow with pressure-inlet | lummz | FLUENT | 3 | October 13, 2012 13:29 |
help with compressible flow BC's (need subsonic flow) | meangreen | Main CFD Forum | 5 | July 24, 2010 13:16 |
compressible flow through a pipe | rajiv | FLUENT | 0 | April 3, 2010 00:36 |
