Exporting isosurface data
Hi all,
I have a velocity field in a plane section (contour plot). I have created an isosurface: number of isosurfaces: 50 range: the range of my velocity values Then I am trying to create a xyz internal table, giving as input part the created isosurface and as scalars the velocity k. When I am exporting the table in csv format I am getting a message: 'Command: TableExport error: Server Error Could not write export file: no data to write' Do you think that is a really stupid idea to export isosurface data using a xyz internal table? |
Did you try checking the data on vertices button?
I suspect because there's no cell data the table doesn't know what to do. |
[QUOTE=me3840;641071]:):) Thanks a lot me3840 ! It works perfectly including the ''vertices command''. However, the problem was in the ''extract command''. The programme stuck for some reason that I have not found out yet.
