No prism layer generation at the interface- solid/fluid |
March 24, 2017, 06:03 |
Akanksha Rawat
Rep Power: 12 |
Hi Guys,
So I am working on FSI and I am using thin mesher and prism layer too (polyhedral and surface remesh also) in Star ccm+ (version 11.04). I have enabled the automatic thin/bulk shape detection and when the volume mesh start, it detects the coolant as thin too (ideally it should not). When the Volume mesh is finished I see that thin mesher is working perfectly but the prism layers disappear at the interface and then there are no prism layers in the whole fluid domain. I have already used Part control and applied it to fluid part but when i start volume mesh with that settings the volume mesh shows error- " ERROR: subsurface location (1.85404 0.55268 -0.163788)has no extrusion data. " Extruder::getLayerDistributionForSubsurfacer: Vertex has no extrusion data". and this is during Prism layer subsurface execution. Please tell me what could have gone wrong. |
March 25, 2017, 02:06 |
Rep Power: 24 |
This is a known limitation of the thin mesher, it's in the user guide.
Essentially you cannot have two domains with the poly+prism+thin meshers enabled and have them be conformal. Choose a domain to lose the thin mesh and use a part control to disable it. Your prisms will return. |
Prism Layer (Boundary Layer) Thickness | Peter-27 | STAR-CCM+ | 12 | March 27, 2022 12:25 |
[ICEM] Prism layer not completely forming at intersection | CCHunter | ANSYS Meshing & Geometry | 1 | October 27, 2015 13:09 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Trimmer & prism layer | peresah | STAR-CCM+ | 6 | October 6, 2009 14:39 |
