May 5, 2017, 09:41 |
Optimization Process/grid subdivision
Fabio Mariano
Rep Power: 9 |
Hi, I'm doing an aerodynamic optimization process over a wing. In my CAD file, my wing is subdivided in two parts: the fixed part which geometry does not change in the optimization, and the parametric part, which obviusly will change during oprtimization process.
So I want that at any optimization step, the mesh grid volume is fixed for the fixed part but change only for the parametric part, becouse i want reduce the time for the grid generation. thank you. |
May 7, 2017, 11:52 |
Rep Power: 24 |
To do this and have a conformal unstructured mesh is very difficult.
If you don't care about the mesh being conformal you can easily just make two meshing operations and mesh each one separately, and then once the parametric part updates the other part will not be remeshed. Then at runtime the interfaces will be computed, but it's possible you will not have 100% face matching. |
May 8, 2017, 02:56 |
#3 | |
Fabio Mariano
Rep Power: 9 |
May 8, 2017, 09:33 |
Rep Power: 24 |
No, you can use CATIA's variables if you want. It's easier to use star's though.
Motion parameter optimization | bennn | SU2 | 0 | March 9, 2016 09:03 |
3D design optimization in a rotating frame? | ITA91 | SU2 Shape Design | 2 | May 20, 2015 10:01 |
Total force optimization or pressure force optimization? | robyTKD | SU2 Shape Design | 1 | August 19, 2013 15:54 |
COMSOL: optimization applied to a laminar flow | tdh89 | COMSOL | 0 | April 30, 2012 08:57 |
BOOK ON OPTIMIZATION OF FORTRAN CODES | Alberto | Main CFD Forum | 3 | November 10, 2008 06:07 |
