Attempt to access unallocated storage
Hi All,
I am trying to run a CCM+ simulation in which energy equation is on and there are two multi-component gases. It is a conjugate heat transfer problem. I am getting this error. The error was not there when I ran the solution using only air as gas. I modified to multicomponent gas and the error started. The error statement is: "Attempt to access unallocated totalenthalpy storage in boundary faces xxxx" Where 'xxxx' is the name of my boundary face, which is actually a periodic face. One more thing, if I remove the periodic BC, the error vanishes. So by either of the two things, error vanishes. 1. Use standard gas (ex. air) OR 2. Remove periodicity. Thanks a lot |
I get this error now, could you solve this error?
I get this error now, could you solve this error? If yes, please tell me how to solve it,thanks very much.
I exactly do not remember what I did a year back :)
But you can check the periodic faces matches and mesh refinement. I am not sure. Good luck. |
Named Storage does not exist in parcels in continuum: Physics 1 lagrangian phase
"Named Storage does not exist in parcels in continuum: Physics 1 lagrangian phase: Phase 1: variable = LinkMark, storage=LinkMark"
- do you know what does this mean? I am copying a lagrangian phase and running the simulation. |
