August 17, 2017, 11:06 |
stagnation inlet
Mustafa
Rep Power: 9 |
hi guys
i want to use stagnation inlet to define a pressure inlet. i created a time-pressure table. but i am confused. what should the pressure unit be? pascal or kpa? thanks |
August 18, 2017, 15:40 |
Matt
Rep Power: 17 |
My server is down, so I cannot open CCM to check this out but I believe that it is whatever your preferred units are in tools > units. If you had a field function then you would want to make sure everything is in basic SI units, but I am pretty certain that tables use preferred units.
August 18, 2017, 15:58 |
Ali dashti
Rep Power: 9 |
Reusing the inlet time directories in timeVaryingMappedFixedValue | ngj_22 | OpenFOAM Running, Solving & CFD | 0 | January 24, 2013 10:22 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
Inlet shapes for modelling a fan in an inlet duct | buzzybee | CFX | 10 | June 11, 2009 20:15 |
Slow convergence using stagnation inlet | pad | STAR-CCM+ | 2 | May 27, 2009 05:17 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
