November 6, 2017, 14:39 |
Pressure outlet boundary condition
Miguel
Rep Power: 8 |
Hi everyone! I was conducting a combustion simulation with ppdf model, where I have several pressure outlet boundary conditions, where they are actually inlet conditions. My doubt is in the Mixture Fraction Profile of the pressure outlet do I have to put [0,1] to indicate that is air(oxidizer) that is entering? Or by default is oxidizer?
The point is I have monitoring the mass fraction at that specific boundary, and it is correct, however, when I put [0,1] it is still correct, but sometimes I star to have a combustion process in the boundary when it is far away from the burner, and no fuel is present there. Thanks all |
November 10, 2017, 01:42 |
Rep Power: 24 |
The default may differ depending on the number of species. You must enter in a correct mixture fraction, yes.
I would not advise using the pressure outlet as an inlet. Stagnation inlet is better formulated for this. If you are having combusion happen where it's physically impossible this suggests your simulation is not converging or has other problems. |
November 10, 2017, 10:56 |
Miguel
Rep Power: 8 |
Dear me3840, thanks a lot for your time. Yes I understand that I don't have convergence. In fact when i say that the only entrance is air, I have a non physical solution, in the control volume I have a considerable number of cells in the sum of mass fraction is well below 1. I will follow your advise and see if Stagnation inlet works better in my case. Thanks a lot for the help
combustion, pressure outlet |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Static pressure boundary condition at outlet | jennz | CFX | 4 | February 11, 2014 04:29 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
