Propeller nominal wake: KVLCC2
Old   November 27, 2017, 14:50
Default Propeller nominal wake: KVLCC2
Soroush Kargar
Seervan is on a distinguished road
Hi all
I am trying to asses nominal wake fraction of a ship model: KVLCC2
I have determined the velocity contours at propeller disc. So my question is how to determine nominal wake fraction, w ?
The relation is w=1-Va/U which U is the ship or flow velocity.
My guess is that I extract the x-velocity values at propeller disc which are the Va values at every cell, then extract them as a XYZ table as .csv, then use the above formula to asses w at every cell, then take an average on them. Is this approach correct? Any ideas?
Tnx
Seervan is offline   Reply With Quote
Old   December 6, 2017, 11:58
Dong Seo
wester is on a distinguished road
After extracting the velocity components, you need to do some post-processing. Please have a look at the following document. There is a description about the post-processing.
https://ittc.info/media/4202/75-03-03-02.pdf
wester is offline   Reply With Quote
Old   December 10, 2017, 11:44
Soroush Kargar
Thanks for the answer
By the way I also found a simple approach that can be useful and it satisfies the ITTC conditions. after forming the propeller disc and converged results, you can define a field function defining the wake. Then create an Surface Average Report within the pertaining node on the related disc. The Surface Average complies the wake integral formula suggested in the references such as "Marine propellers and propulsion" by Carlton, pp.67. Thus you don't need to tabulate the data on the disc and post process them in the hard way.
I validated the data with the MOERI experiment and there is good agreement.
Cheers
Thread Tools
Trackbacks are On
Propeller calculation toil CFX 15 May 22, 2017 04:06
having problems with implementing the wake rollup for a panel method smilesgiles89 Main CFD Forum 0 August 6, 2015 20:09
wake behind propeller samy_20042004 CFX 1 November 29, 2012 16:17
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
propeller in non-uniform flow ubik Main CFD Forum 0 February 20, 2007 06:28
