Measuring Normal Stress and Shear stress
Old   December 7, 2017, 04:26
Default Measuring Normal Stress and Shear stress
AS_Aero is on a distinguished road
Hi
I am trying to calculate the Normal stress and Shear stress component of a straight water jet hitting on a wall which is normal to the wall and at various angles
I could only calculate the Force on the wall or taking surface average of the force due to pressure or shear or both..
But I dont think this is the correct way. So if someone know how we can calculate them, it would be really great from your side.
AS_Aero is offline   Reply With Quote
Old   December 7, 2017, 12:51
acalado's Avatar
André
acalado is on a distinguished road
I believe "normal" forces acting on the wall should all be due to the pressure acting on it. Shear forces will act tangentially to the wall surface. So these should be readily available in the field functions of pressure and Wall Shear stress.
If you want to look at the energy dissipation you may look at elongation and shear viscous dissipation:
This should be valid only within the fluid domain, so it evades your question (plus it can be tricky to program as user defined field functions and should highly depend on your mesh quality)
Sapere aude!
acalado is offline   Reply With Quote
Measuring Wall Shear Stress in 2D pipe flow ritwik_101 FLUENT 0 November 10, 2017 00:04
Measuring wall shear stress in bend pipe liguifan OpenFOAM 70 December 9, 2015 03:49
Plot normal and shear stress sagga FLUENT 2 July 15, 2005 00:46
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
