December 19, 2017, 06:17 |
conformality check skipping
Akanksha Rawat
Rep Power: 12 |
Dear users,
I am not able to figure out why ccm+ is skipping the conformality check. Even though i have created interfaces which are conformal! could you please let me know about the possible mistake in my case! Thanks |
December 19, 2017, 06:26 |
If you had created interfaces using surface repair then wouldn't they be automatically conformal ...
December 19, 2017, 06:55 |
Akanksha Rawat
Rep Power: 12 |
@ashokac7
I did not create the interfaces using surface repair. The interfaces were created while creating regions. |
December 19, 2017, 09:33 |
Check if there are contacts in geometry node. If contacts are there then interfaces will automatically be conformal. Otherwise, Create interfaces in surface repair >> multi-part imprint with right tolerance. Then You will have contacts and ultimately conformal interfaces.
December 19, 2017, 14:53 |
Akanksha Rawat
Rep Power: 12 |
Thank you!! I have made imprints in CAD only but i was worried why ccm is not considering the interface check while volume meshing!
CFD Post - How to check for case in an expression | pilakin | ANSYS | 0 | September 26, 2014 04:44 |
Mesh check failed | subhas.hunasikatti@gmail. | FLUENT | 0 | January 19, 2014 04:09 |
[ICEM] Understanding check mesh output | kotimari | ANSYS Meshing & Geometry | 0 | July 15, 2012 08:33 |
faceZones and topological check | mturcios777 | OpenFOAM Programming & Development | 0 | June 15, 2012 13:48 |
Cell check and Boundary check errors | AB | Siemens | 4 | October 28, 2004 13:04 |
