How to use SLURM to run STAR-CCM+ simulation
Old   December 19, 2017, 10:17
Default How to use SLURM to run STAR-CCM+ simulation
calmdown911 is on a distinguished road
I have a difficult problem which I hope someone would be so kind to help me out:
I need to use SLURM to run a STAR-CCM+ simulation. But I don't know how. I tried to write a script by myself. But the job could be submitted but will immediately failed with ExitCode 2.
Here is my script:
#!/bin/bash
#SBATCH --job-name 1218
#SBATCH --partition=DELL
#SBATCH --nodes=4
#SBATCH --ntasks=28
#SBATCH -n 84
#SBATCH -output=1218.out
#SBATCH -e error_flie.e
#SBATCH -t 12:30:00
#SBATCH --mail-type=all
#SBATCH --mail-user=abc@def.com
module load starccm/12.02
module load mpi
sim_file="1218.sim"
STARTMACRO="/home/MYCASE/run.java"
starccm+ 1999@abc.com -np 84 $1218.sim -batch $STARTMACRO -batch-report
calmdown911 is offline   Reply With Quote
Old   December 19, 2017, 13:39
Paul Hancock
Paulh is on a distinguished road
Take a look in the STEVE-Portal. There is an article with a couple of script examples.
Paulh is offline   Reply With Quote
Old   December 19, 2017, 14:15
I submitted that question and the scripts seems not working.
Old   December 20, 2017, 12:22
me3840 is on a distinguished road
Please post the complete error the scheduler is writing out.
me3840 is offline   Reply With Quote
Old   December 21, 2017, 10:29
SLURM Job_id=56375 Name=1214 Failed, Run time 00:00:00, FAILED, ExitCode 2
Old   December 21, 2017, 14:40
The complete error message is as below:
Thank you so much for your help!
Old   December 22, 2017, 11:51
Andre C
spartan42 is on a distinguished road
Is that the error given to you by the output file? [1218.out]
spartan42 is offline   Reply With Quote
Old   December 22, 2017, 12:03
Andre C
Maybe you can benefit out of my slurm file:
#!/bin/sh
#SBATCH --account= [your account]
#SBATCH --time=20:00:00
#SBATCH --nodes=4
#SBATCH --ntasks-per-node=28
#SBATCH --mem-per-cpu=1990
#SBATCH --job-name= [job namr]
#SBATCH --error=Job_Results_ERROR-%J.err
#SBATCH --output=Job_Results.out
#SBATCH --export CDLMD_LICENSE_FILE = [1999@ your license]
export CDLMD_LICENSE_FILE=[1999@ your license]
## Simulation File: ====> Source
STARSOURCEFILE=[simulation name.sim]
## SLURM: ====> Job Node List (DO NOT MODIFY)
echo "Slurm nodes assigned :$SLURM_JOB_NODELIST"
echo "SLURM_JOBID="$SLURM_JOBID
echo "SLURM_JOB_NODELIST"=$SLURM_JOB_NODELIST
echo "SLURM_NNODES"=$SLURM_NNODES
echo "SLURMTMPDIR="$SLURMTMPDIR
echo "working directory = "$SLURM_SUBMIT_DIR
echo "SLURM_NTASKS="$SLURM_NTASKS
## Modules: ====> Loading desired mudule (DO NOT MODIFY)
module load starccm/starccm-10.02.012
## Working Directory: ====> Job Node List (DO NOT MODIFY)
cd $SLURM_SUBMIT_DIR
scontrol show hostname $SLURM_NODELIST | tr 'ec' 'ic'> machinefile_${SLURM_JOB_ID}
starccm+ -batch -np $SLURM_NTASKS -rsh ssh -machinefile machinefile_${SLURM_JOB_ID} -power $STARSOURCEFILE &>> job_$SLURM_JOB_ID.log
sleep 3
##rm $hostfile
echo "Run Finished" >> job_$SLURM_JOB_ID.log
Old   December 23, 2017, 10:08
#!/bin/sh
#SBATCH --nodes=4
#SBATCH --export CDLMD_LICENSE_FILE=[1999@ your license]
sleep 3
##rm $hostfile
Thank you so much! I'll try your script. Hope it works!
Merry Christmas!
Old   December 23, 2017, 14:36
The error is send by email.
Old   December 23, 2017, 14:39
Andre C
tmas to you as well!
Old   December 23, 2017, 14:41
Andre C
I hope it works. Let me know if you need some help.
Merry Christmas to you as well!
Old   December 24, 2017, 11:53
Hi, Spartan42,
I tried your scripts and got the error as below:
ModuleCmd_Load.c(213):ERROR:105: Unable to locate a modulefile for 'starccm'
What shall I do for this kind of error?
Old   December 24, 2017, 12:01
Andre C
Hi, Spartan42,
If you look at the script/ the section on the bottom is loading the module for starccm on the server. You need to find out the file directory.
I imagine your using some sort of command/ or putty. Correct?
In the command promp you can type [module avail] and it should populate a list with all the available modules on the server. From there you can search for the starccm module and replace the red part with yours
Old   December 25, 2017, 09:40
Hi, Spartan42,
It seems I finally got the simulation running on our cluster. Yet I came across another problem. I activated autosave when I built the case. Yet I cannot get the calculation result. The case file is exactly same before and after the calculation. The residual is recorded in the output file. Yet the result seems lost. What shall I do to get the calculation result from SLURM?
Old   December 25, 2017, 09:55
Andre C
Hi, Spartan42,
Can you elaborate a little more?
This is what I got:
You set auto save every x amount of iterations? But its not saving the new sim file correct?
You are getting the residuals from the output file because they are the only active reports in your simulation. If you create other reports and graphs you will see those results in the output file.
When it comes to simulation saving/ - you need to set up the autosave for every x iteration - might be not set up correctly and that is why your not seeing anything. If you getting residuals it means the simulation is running. Maybe take a snip of your autosave setting so i can look at it.
Old   December 25, 2017, 11:42
This is what I got:
My autosaving is as attachment. Is it right?
Old   July 1, 2020, 04:18
MA
mazhar16823 is on a distinguished road
Merry Christmas!
I have used this script but it gives me an error "invalid argument" for my account. Why is this happening?
mazhar16823 is offline   Reply With Quote
Old   July 11, 2020, 19:34
Erik Lönroth
erik_lonroth is on a distinguished road
Perhaps this could be of help for you aswell https://eriklonroth.com/2020/07/11/r...nd-infiniband/
erik_lonroth is offline   Reply With Quote
Old   August 8, 2020, 08:22
Sebastian Engel
bluebase will become famous soon enough
If you have a cluster with time limits for jobs, you might like my script https://wikis.ovgu.de/lss/doku.php?i...rccm#variant_1
It tells slurm to send a signal, when a job is about to reach its time limit. The above script traps that signal and will write an ABORT file into the work directory. That way, starccm can stop gracefully.
The advantage with this method is you will not lose the computation since your last (auto)save.
As long as you have an active stop file stopping criterion this methods will work with macro-based runs as well as command-style runs.
Anyhow, this script contains some lines which are specific to my university's cluster. This includes the compute node's resources, name of queues, work directories, availability and names of modules, custom prolog and epilog scripts, and mpi settings.
Of course, you need to adapt these information to your system.
bluebase is offline   Reply With Quote
clusters, mpi, slurm, star-ccm+
Marine Propeller Hydroacoustic Simulation in Star CCM BlackEagle STAR-CCM+ 1 December 8, 2017 21:33
abaqus star ccm co simulation Mustafalboro STAR-CCM+ 0 July 25, 2017 16:13
Run STAR CCM+ with -power by default Jorgror STAR-CCM+ 2 February 16, 2016 08:46
Thermal Comfort Simulation in STAR CCM+ anupmu STAR-CCM+ 1 February 27, 2013 14:25
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 04:37
