January 2, 2018, 10:22 |
Multi solid interface mesh
Charles Dhainaut
Hello everyone,
I am a very beginner with Starccm+ and I try to mesh a multi solid geometry. I read that I had to create an interface between the two solids to avoid this type of mesh at an interface between two solids : But after I create this interface I don't know what is the procedure to make a smooth mesh at the interface between the two parts. Do you recommend a tutorial to help me to do this ? Thank you very much |
January 2, 2018, 23:14 |
Give same mesh values at interface surfaces. If you have not captured curves then do that first. Capture the part curves with default setting in geometry node and then assign these to region. This will mostly solve your problem.
January 8, 2018, 00:52 |
Rep Power: 24 |
Is this a wrapped geometry?
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
