[Sponsors] | |||||
Alessandro
Rep Power: 9 ![]() |
Hi everybody, if i want simulate a drone ( turbolences, blades) ecc. Which is the best way? Can i have a tutorial or a best pratice?
Matt
Rep Power: 19 ![]() |
That is a very open ended question. If you are a novice, this simulation is probably well beyond your ability at the moment. I would start with some simple tutorials and build your way up in terms of complexity. There are several different ways to approach any one aspect of your analysis and you need to decide what you are trying to get out of it first.
Alessandro
I'have already simulate a case of internal aerodynamic. I am not a novice, but this is the first approach with the external aerodynamic. I have seen that there is a lot of things to investigate:
- turbolence - blades analysis ( b.e.m. blade element method) Thanks |
Matt
There are a couple different external aero examples that would be beneficial. The blade element method is good, but I would repeat that it depends on what you want to get out of it. Your choice of turbulence model will also depend on your end goal. Can you be more specific about what you are trying to accomplish?
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
| Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
| Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 06:55 |
| setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
| Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
