March 1, 2018, 06:26 |
Question about “Assign Parts to Regions”
Rep Power: 8 |
I have already spilt one surface by path. And then i got 6 different surface. When i click "Assign Parts to Regions" , there are only one boundary in regions. However, in the guide book, it has 6 boundary. I don't know why. I followed it step by step.
March 1, 2018, 08:56 |
Rep Power: 10 |
Just try the Option "Assign a Boundary for each Part Surface"
March 1, 2018, 12:48 |
Rep Power: 8 |
Yes. I chose this option.
March 1, 2018, 14:43 |
Rep Power: 8 |
And the error is "No Interfaces were created"
March 2, 2018, 00:53 |
It is not an error. If there is a single region then why it will form interfaces. And as Jonass19 said, your problem should be solved by assigning separate boundary for each part. May be you are doing some mistake while assigning the parts. Do it again. If not you can split the boundaries also by same method you have split the parts. Or go to geometry (Keep the region as it is) and right click on part and create a separate boundary from drop down menu. Hope this helps.
March 2, 2018, 03:32 |
Rep Power: 8 |
Yeah, it's OK. I click "assign parts to region" first which gets one boundary. Then i return the geometry to create a boundary for each surface. Thank you every much.
December 13, 2018, 13:03 |
Pranjal
Rep Power: 8 |
Choose one boundary for all surfaces, then you will have just one boundary for all regions
“assign parts to regions” |
How to connect interface between 2 parts in Ansys Meshing. | arlu | FLUENT | 4 | October 22, 2019 01:59 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 20:31 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
