March 7, 2018, 03:10 |
Help with Star CCM versions
Rep Power: 8 |
I have a Star CCM+ 12.02 version installed on the system I access
For a problem on Quenching simulation, I downloaded two sample simulation problems from the Steve Portal. After downloading I found out that those problems have a version of 12.04. Hence, I am unable to open those in my older version of software Is there any way to open them or are older versions of those simulation files available on the Steve Portal? The files are : "QuenchingHeatTransferExample.sim" and "TransitionBoilingExample.sim" Kindly help |
March 7, 2018, 17:06 |
Rep Power: 24 |
No, sim files saved in a new version are not backwards compatible.
March 8, 2018, 03:20 |
If you have access to Steve portal then you can download a latest version their. And install latest version without uninstalling older one. And if you are using server based license you don't even have to set up license file again.
quenching, star ccm+ 12.04, transition |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
how to open star ccm 6.04 version file in older versions | pritam.edke | Siemens | 2 | June 25, 2012 03:14 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
