Help with power transformer radiator simulation |
March 6, 2018, 22:02 |
Marcos Vinicius
Hi Everyone!
I'm creating a new simulation for a power transformer cooler (heat exchange or radiator) using STAR-CCM+. This is a heat transfer conjugated with convection and conduction. I have some difficulties to define the regions and volumes for the fluid inside the radiator (Oil), for example. What's the right sequence or steps may I follow to build the pre-processor for this simulation? Please, anyone can help me? I attached 2 images to help understand the model i trying to simulate. Thanks in advance! |
March 7, 2018, 00:59 |
Rep Power: 24 |
For any CHT simulation:
1. Use whatever means you see fit to produce a volume of each fluid and solid part 2. If necessary, imprint the parts together to create contacts between interface surfaces 3. Assign the parts to regions 4. Configure and create the mesh 4b. Assess the mesh quality and repeat meshing until satisfied 5. Create the physics and boundary conditions 6. Create any desired reports And all the pre-processing is done. Anything in greater detail requires greater detail of your specific case, which is on you to provide. |
March 12, 2018, 20:24 |
Marcos Vinicius
Thanks a lot. following your steps I'm proceeding very well with simulation.
Thanks very much. |
Power calculation in centrifugal pump - CFD Post | Hazem_9 | ANSYS | 1 | May 11, 2017 14:22 |
Constant Power Fan Model using General Momentum Source | Dano62 | CFX | 0 | April 14, 2016 13:09 |
Problems with power variable | ghost82 | EnSight | 4 | January 2, 2015 09:52 |
oil flow in power transformer | gapoeng | FLUENT | 0 | January 19, 2014 23:58 |
Wind Power | Frank Grassi | FLUENT | 0 | October 12, 2007 11:20 |
