December 7, 2016, 20:23 |
DEM Track File Output
Robert
Rep Power: 9 |
Hi there,
I am running a DEM simulation where the end result is a densely packed pebble bed. All of the pebbles have the same radius. I want to be able to create the exact same pebble bed in another program (Serpent), which requires simple (x,y,z) coordinate inputs via a text file. Is it possible to get the StarCCM+ .trk file converted into some other file type so that i can simply extract the cartesian co-ordinates for the centroid of each particle? Perhaps output as a .csv file? Cheers. |
May 15, 2018, 14:14 |
Casey
Rep Power: 16 |
Did you get anywhere with this? I have defined a table, but wish I could work directly with the track file for post processing.
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
