March 29, 2018, 07:16 |
Error importing .prt file into 3D-CAD Models
I have a simple 3D CAD model with different parameters defined as expressions, such as 'Chamfer Offset' and 'Extrude End Limit'. This is done to perform an optimazation study in STAR-CCM+. Everything works out with exporting in Simcenter NX but when I import the .prt file as 3D model I get the following error: Error during CAD import. Details in log file D:\...\Block.prt.log With the following details in the log file: Command line : --input D:\Block.prt --output C:\Users\student\AppData\Local\Temp\661d1814-5282-424b-a5e6-3259737d6378.x_t --parasolid_pass_through --logfile D:\Block.prt.log HOOPS Exchange 10.2 64-bit Unicode PK 30.0.269 ERR LoadFromFile Error -10005 D:\Block.prt If I export the CAD model into a .STL, .STEP or .x_t it works fine but then I am losing my parameters which is the most important part of my design. Help is really much appreciated, thank you! |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
