April 27, 2018, 09:43 |
Calculate pressure drop in a trombone cooler
Ingrid Sandvik
Hi!
We are a group of students working with our bachelor thesis. Our goal is to simulate a U-tube cooler using Star CCM+. We have got som measured values from a existing cooler; pressure, velocity, flow and temperature of the gas. We have for the most used velocity inlet (for the two inlets) and pressure outlet, and the outlet temperature from the simulation is quite similar to our measured values. Our problem now is that the simulated values for pressure is far away from the correct value. We have tried to change backflow specifications to static pressure for the outlet, and we have applied the measured pressure of -1280Pa at the outlet. The simulation diverges after a few iterations. Any suggestions on how to correctly calculate the pressure drop is appreciated. Thanks! https://imageshack.com/a/img923/926/L1fIEk.png |
May 13, 2018, 17:22 |
Chaotic Water
Rep Power: 17 |
Physics, Mesh, Boundary Conditions = ?
Fluent cyclone pressure drop | mkal | FLUENT | 1 | February 20, 2020 00:55 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Polydispersed phase pressure drop with drop size | Laksh | CFX | 1 | June 8, 2017 18:56 |
You can calculate the pressure drop in two-phase flow? example, slug flow or stratifi | Mechaniker | FLUENT | 0 | December 22, 2014 11:04 |
Calculate pressure drop using workbench | rusted86 | Main CFD Forum | 0 | April 5, 2012 10:52 |
