Error: Rigid Body has empty Surface
Old   May 15, 2018, 12:54
Default Error: Rigid Body has empty Surface
Lucas Goulart Duarte
xlucasgoulart is on a distinguished road
I'm learning how to use STAR CCM+ now for a project and I'm currently working on a simple simulation of a sphere close to the free water surface.
Whener I try to run the simulation, instantly, the error occurs. This is how it looks:
File Type: jpg Captura de tela de 2018-05-15 13-53-32.jpg (93.2 KB, 35 views)
xlucasgoulart is offline   Reply With Quote
Old   October 25, 2018, 01:55
Jon Faried is on a distinguished road
I've encountered a similar problem (also with a body which is supposed to float on a free water surface). Any chance you've figured out the solution since you posted this?
Thanks!
Jon Faried is offline   Reply With Quote
Old   October 25, 2018, 03:20
OK, scratch that. I simply forgot to select all of the wall components as the parts forming the rigid body.
This is why we drink coffee.
Old   April 17, 2025, 04:58
Elian
s4crebleu is on a distinguished road
Hi Jon, Im currently encountering the same problem and Iwas wondering what you meant by "select all the wall components"? Any chance you could clarify on that please?
s4crebleu is offline   Reply With Quote
[cfMesh] Surface topology (wanted: ok (non-closed singly connected), is: ok (empty)) ??? Helene OpenFOAM Community Contributions 1 April 19, 2018 06:49
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[DesignModeler] Smaller surface body from face bongbang ANSYS Meshing & Geometry 1 June 29, 2015 02:28
[DesignModeler] how to subtract a surface body from a solid body? yahya ANSYS Meshing & Geometry 4 January 7, 2013 11:00
Free surface and moving body Steve Siemens 4 August 20, 2004 11:06
