May 27, 2018, 13:53 |
How to set the meshing for DNS
Songkai Yang
Rep Power: 7 |
Hi everyone,
now i want a simulation with DNS and RANS. Then compared the results of these two each other. when i set the meshing for DNS, need i set the prism layer mesher for the boundary layer and consider the y+<=1? Moreover the inlet velocity is cycle data. if i need consider y+<=1, the max velocity in the cycle should be used to get the first grid distance delta s? Thanks a lot! |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
