Questions about rotation rate in motion
Old   July 30, 2018, 06:12
Question Questions about rotation rate in motion
Xiaosong Zhang
jsb12136 is on a distinguished road
Hello everyone.
Currently I am using Starccm to model a vertical axis turbine with variable pitch. The turbine has constant rotation speed but each blade of the turbine is changing the pitch as the turbine rotates. I am modelling with superposed motion of the blade and the only way to control the blade pitch is to input the rotation rate (which is under the superposed motion tree). The question is that my main objective is pitch angle although rotation rate works to some extent, the results are not very satisfied. Is there any way to control this motion directly with pitch angle using field funtion or something else? Thank you.
jsb12136 is offline   Reply With Quote
motion, rotation, rotation rate, starccm+, superposed rotation
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
UDF to determine rotation rate. Plz help. Zedd FLUENT 0 March 13, 2017 08:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
3D Fan:Calculation of induced flow rate by fan rotation at free delivery Catthan FLUENT 3 November 6, 2013 05:19
Restrict motion in 6-dof to rotation tiam FLUENT 0 March 15, 2012 06:27
