Convergence Problem for Multiphase flow
I am doing Detailed Simulation of Fuel cell with almost 70 million cells. The model worked for single phase flow and i got good convergence and results. But when I change the model to Multi-phase, even the Flow solver is diverging with the same initial conditions as in single phase case and with the results (Pressure and velocity) of single phase as initial conditions for the multi-phase case. I am playing around with the damping factors, convection methods (1st and 2nd order) but there is no use. Flow conditions: steady,Turbulent with k-epsilon, Eulerian multiphase Output window is showing as some warnings as follows: Pressure corrections limited on ------ Turbulent viscosity limited on ------- reversed flow Can someone help me on this. Thanks and regards, Naveen |
And give more info on the issue like set up properties, BC's, residuals, and whole error message etc for better comment. |
Were you able to solve the issue
Can someone help me out with possible reasons for the same? I can give more details as required. PS: Mesh is unstructured and mesh quality, orthogonality and aspect ratio is well within limits |
