September 17, 2018, 22:33 |
Particle seem to go through wall boundaries
Obed
Rep Power: 9 |
Hello star CCM+ community, can someone out there be having an idea on the cause of these two issues in star CCM+.
I have a 3D model with air surrounding a membrane of aligned fibers. On this I have a velocity inlet, pressure outlet, symmetry sides and my membrane clearly defined as a wall. I'm trying to run a two-way coupled CFD-DEM simulation. However; 1. In the visualization scene created, particles can be be seen going through fibers. Instead according to the particle-particle and particle-wall interaction settings used, I would expect them to stick on colliding with the fiber to form some progressive surface buildup. (I have managed to get this with one-way coupling). 2. Also, sub-stepping is active on every iteration unlike in one way coupling where it happens once every time step. This makes the simulation process very very slow. I appreciate a lot |
March 2, 2023, 10:19 |
#2 | |
Mahmoud
Rep Power: 5 |
Hi akaobi, Have you found an answer to your question? Best Wishes, Mahmoud |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
particle does not stop | YANNAPOL | Fluent UDF and Scheme Programming | 2 | June 13, 2015 00:28 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Floating Point Exception - wrong boundaries or general PC problem? – OF 1.6 extend - | A.Wendy | OpenFOAM | 0 | February 27, 2013 04:50 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
