Simulation of helicopter blades using periodic bc |
September 29, 2018, 07:32 |
JOHN SHERJY SYRIAC
Rep Power: 7 |
Hi
I am simulating the flow over the 4 bladed helicopter rotor in hover configuration using LES. Since the flow is periodic, i wish to simulate the flow in an quadrant using periodic boundary condition..Kindly help me to solve the pbm i used wall slip BC at all outer boundaries. The two inner faces are subjected to periodic BC. I am not being to get the solution as it is diverging. 1)Can u use this condition when i am using implicit solver. The inner region is rotated with a specific rpm using rigid body motion. I hereby attach the screenshot of the geometry. Thank you in advance |
July 23, 2020, 07:39 |
David Lehnardt
Rep Power: 8 |
Hey,
Did you manage to get it to work? I am currently modeling an identical problem, but I am imposing the rigid body motion on the entire domain. I am using DES with k-omega in the near wall region, but my residuals are just hovering above 1E-2... My time-step is equivalent to one degree of rotation. |
Transient Simulation in CFX | ashtonJ | CFX | 1 | September 28, 2018 01:18 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
HELP PLS: Helicopter rotor simulation in fluent | samcfd | Fluent UDF and Scheme Programming | 0 | January 4, 2016 23:12 |
Periodic boundary conditions for moving reference frame (MRF) simulation) | guebelib | STAR-CCM+ | 1 | April 15, 2015 06:55 |
[ICEM] Shifted Periodic topology | venkat_aero2007 | ANSYS Meshing & Geometry | 17 | August 27, 2013 01:41 |
