January 17, 2024, 09:41 |
Mesh interpolation
Matteo Liguori
Hey everyone,
I've been diving into the world of bird simulations and hit a bit of turbulence (pun intended!). Started out with your standard unsteady k-omega setup to study our feathered friend in various angles of attack. Got some cool data on pressure, velocity, and vorticity fields – all the good stuff. Then I hit a snag. Needed to solve a special equation (check out the image attached), so I rigged up a new sim. This time I went with Finite Element solid energy, tweaked the material properties, and voila, got the derivatives I was after. Turns out you can't trick the gas domain solver into ignoring the extras we don't need, so I went the solid route. Now for the tricky part: I've got two sets of solutions on two wildly different meshes and domain types. And I need to merge 'em. Tried to coax Star-CCM+ into doing the heavy lifting, and when that didn't pan out, I attempted exporting the data to CGNS and wrestling with it in MATLAB using cgns4m. But no dice. So, I'm throwing this out to all you CFD gurus – got any magic tricks up your sleeves for interpolating one solution set onto another? Any tips would be a lifesaver! Cheers! |
January 18, 2024, 13:29 |
Rep Power: 17 |
Have you tried the volume data mapper? Other than the help file, here's a link to additional instructions:
https://support.sw.siemens.com/en-US...00031549_EN_US |
fluid domain, mesh interpolation, solid domain |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? | ptpacheco | OpenFOAM Meshing & Mesh Conversion | 1 | January 4, 2022 12:37 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
