Change deprecated class in a macro
I am running the parseSTARCCMModel.java macro that comes with heeds, and uses the following in one of its line Code:
else { Deprecated. As of release 13.02. Use "getQuantity::getValue" method on the concrete class instead. So, does anyone know what should be done in order to change the getValue() method? Also a direction for how to refer the java api would be much helpful for future reference. Kind thanks, |
If you search the Steve portal there are articles on how to connect your IDE to the Java libraries that come with STAR. They will help you replace what you need.
