December 18, 2018, 12:32 |
Problem with .stl
Rep Power: 7 |
I am using NX11 to draw my aerodynamic devices. Once I am finished with the project I export it as .stl file. As option I use 0.080 = chordal Tolerance (I want to go at 0.0025) and 18 = angular tolerance (here I want to try 1). At the end I import all my devices in StarCCM.
Where is the problem? I tried to export three types of configuration of the car: simu000 I loaded the car in NX and then exported, simu002 I rotate the car with the 3D mouse and exported, simu001 I closed the NX file and reopened and reloaded the same car (I want to underline that the car is always the same, with the same pieces). I ran all three simulations with exactly the same Macro (I generated three macro: Straight, Heavy braking, yaw, for this experiment I used Straight) and what I got, was a bit strange: with two simulation I had the same results (simu000 and simu001) but with simu002 I received different results. To find the problem I exported from NX the .txt file and I compared all three files. What I discovered is that in some aero devices there are different mesh. This is an exemple: simu000 : facet normal ni nj nk simu001: facet normal ni nj nk outer loop outer loop vertex 0 0 0 vertex 1 2 3 vertex 4 5 6 vertex 9 8 7 vertex 7 8 9 vertex 0 0 9 endloop endloop endfacet endfacet The triangles have a different normal and different vertex. What can I do to avoid this problem? The problem is in the meshing of StarCCM or NX? In StarCCM I make a surface wrapper -> surface remesher -> trimmer -> prism layer. I really appreciate your effort to help me. Thank you; |
December 22, 2018, 19:35 |
Rep Power: 24 |
If NX is for some reason not outputting consistent STL files, why not just export it in a CAD format instead.
December 23, 2018, 08:56 |
Rep Power: 7 |
Problem with .stl file | Kamui | Main CFD Forum | 0 | December 17, 2018 10:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
