April 5, 2019, 11:58 |
Problem while Meshing StarCCM+
Akshay Anand
Rep Power: 7 |
Dear all,
I encountered a problem while meshing a geometry using StarCCM+. I have a geometry that I enclosed in a sphere, and further, I enclosed this complete set-up into a cylinder. The meshing on geometry is fine but moving away from geometry the size of the cell is increasing in my case (which is still okay, but) I need a gradual increase in the size of the cell (attached file). Furthermore, the meshing on extreme outer domain i.e cylinder is completely fine. Is there any way to control the size of cells so that the size of cells increase gradually/progressively? I will be grateful if anyone can help or give a helpful suggestion. Thanks in advance [IMG] https://ibb.co/QPhHDNm[/IMG] Last edited by akkiturb; April 7, 2019 at 20:14. |
April 9, 2019, 10:14 |
Matt
Rep Power: 17 |
There should be growth rate and/or max cell size options in the meshers you can configure. If that doesn't get the job done then maybe an unstructured mesh isn't really what you want and you will need to consider importing a mesh from something that can do structured mesh.
April 15, 2019, 19:55 |
Steve
Rep Power: 8 |
Otherwise trimmed mes, polyhedral mesh does't have maximum cell size function in mesh continua.
you should control that using surface size, volume comtrol and growth rate only. |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Gambit meshing problem to following geometry | ahmadmln | ANSYS Meshing & Geometry | 2 | October 21, 2014 01:49 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
