May 8, 2019, 07:27 |
Loading user code in Windows
Yogesh Nalam
Rep Power: 13 |
I compiled a user code (*.so) in Linux using the command : gcc -fPIC -shared *.c -o libuser.so Can I load the generated libuser.so file into Star CCM+ on a Windows machine ? When I do that, I am always getting this error of memory access violation. Any help would be appreciated. Thank You! |
May 13, 2019, 04:31 |
Sebastian Engel
Rep Power: 20 |
Hi Yogesh,
as the manual indicates this is not possible. You have to compile the user library on the windows machine separately. With some further studies of the differences between unix and microsoft world, you will get to know why. Anyway, recheck the StarCCM manual, it also explains how to compile the library for windows from its source. Best regards, Sebastian Last edited by bluebase; May 13, 2019 at 04:38. Reason: wording |
May 13, 2019, 04:34 |
Yogesh Nalam
Rep Power: 13 |
Hello Sebastian,
Thank you for the response. Yes, I now get it and have compiled seperately. Kind regards, Yogesh |
memory access exception, unix, user code |
Create a user code | HN_Hoang | STAR-CCM+ | 3 | December 27, 2020 03:15 |
How to successfully export jpeg image with User defined Windows Size in Batch mode | potofus | EnSight | 2 | April 26, 2016 03:25 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
user friendly cfd code | waqar | Main CFD Forum | 19 | August 18, 2000 16:31 |
Open source CFD code development, possible? | Dr. Yazid Bindar | Main CFD Forum | 27 | July 18, 2000 00:18 |
