Troubles in solution convergence of rotational flow
Old   May 19, 2019, 06:01
Default Troubles in solution convergence of rotational flow
Ahmed Alhusseny
AhmedAlhusseny is on a distinguished road
I have a channel rotating about an axis parallel to channel but far from it with distance H. The channel walls are heated, and hence, centrifugal buoyancy is expected to play an important role along with Coriolis forces in the development of flow and temperature fields. I set a Rotating reference frame with using Coupled Flow and Energy solvers along with ideal gas to address the change in the air density. However, I have problems in getting the solution converged. Thus, I tried to switch to the Implicit Unsteady solver with timestep 1.e-3, but with no benefit even with reducing the Courant number value to very low levels! This problem is equal for laminar and turbulent flow regimes, i.e. Re=1000 and 10,000, respectively. can anyone help in figuring out this problem?
AhmedAlhusseny is offline   Reply With Quote
Old   May 20, 2019, 04:05
Steve
steve lee is on a distinguished road
when your solution have a problem? just started?
try to control I.C and relaxation factor..
steve lee is offline   Reply With Quote
Old   May 20, 2019, 06:44
Ahmed Alhusseny
I have tried different proposals. First, I used the segregated solve along with ideal gas for incompressible flow, but the residuals start to go up after a slight reduction at the beginning of the solution. I even tried to use a ramp for each of the velocity, pressure, and energy equations, but it didn't make that benefit! Then, I tried to switch the solution to coupled flow and energy, however, the solution diverges few time steps after the beginning!
Old   May 20, 2019, 19:39
Steve
Why do you use ideal gas for incompressible flow?? anyway.. i think it is not the reason of diverged..
if your B.C is reasonable...
try to find where is the problem in your domain..
do you use MRF method? you can try to fixmesh problem and control rotating speed.
Diverging solution for hypersonic flow lipiroy SU2 1 July 2, 2018 12:04
periodic straight tube flow, no mesh independent solution for pressure gradient thijs1909 FLUENT 5 May 16, 2018 09:04
Is solution converged?(Judging convergence)? aja1345 FLUENT 4 February 26, 2016 06:09
Weak rotational flow - Convergence Problems Daggemann FLUENT 1 May 8, 2009 09:45
