Error message when using DBFI
Hello everyone,
I'm trying to simulate a floating roof on oil. However when doing so I get this error when enabling the DFBI. Updating indirect region interface Overset Mesh 1 between Floater and Fluid. Attempt to access unallocated SavedCoord storage in vertices in Fluid Command: StepSimulation Recoverability: Non-recoverable ServerStack: [SymInit: Symbol-SearchPath: '.', symOptions: 530, UserName: 'student' , OS-Version: 6.2.9200 () 0x100-0x1 , 00007FFA01CA0211 (StarPlatform): (filename not available): StarCommandTokenizer::concatenate , 00007FFA01CBF608 (StarPlatform): (filename not available): Uuid::setFromStarString , 00007FF9F20B4548 (StarNeo): (filename not available): NonRecoverableError::NonRecoverableError , 00007FF9F20AD65A (StarNeo): (filename not available): InternalError::InternalError , 00007FF9DECD64D2 (StarStorage): (filename not available): StoredVariable<Vector<3,double> >::getStorageImpl , 00007FF9DECD6FBF (StarStorage): (filename not available): StoredVariable<Vector<3,double> >::Engine::Engine , 00007FF9BBC03D1B (PartitionedCoupling): (filename not available): FluidStructureInteraction::updateMorpherDisplaceme nt , 00007FF9BBC03882 (PartitionedCoupling): (filename not available): FluidStructureInteraction::updateMorpherDisplaceme nt , 00007FF9BBB33092 (PartitionedCoupling): (filename not available): FluidLoadLinearRampAndClipping::getTractionClippin gArray , 00007FF9DF7D87A6 (StarSolve): (filename not available): VerifiedFaceTerm::VerifiedFaceTerm , 00007FF9DF7DB1A4 (StarSolve): (filename not available): VerifiedFaceTerm::verifiedEvaluate , 00007FF9DF7DEF3D (StarSolve): (filename not available): SelectiveFaceTerm::evaluate , 00007FF9BBBFBE7A (PartitionedCoupling): (filename not available): FluidStructureInteraction::computeFsiResponse , 00007FF9BBB9508F (PartitionedCoupling): (filename not available): FixedPointIterativeModel::coupleFluidStructure , 00007FF9BBBA792B (PartitionedCoupling): (filename not available): FixedPointIterativeSolver::iterationUpdate , 00007FF9DF9385AB (StarSolve): (filename not available): RunnableSolver::doSolverIterationUpdate , 00007FF9DF9371E1 (StarSolve): (filename not available): RunnableSolver::iterate , 00007FF9DF804F3E (StarSolve): (filename not available): ImplicitUnsteadySolver::step , 00007FF9DF94521F (StarSolve): (filename not available): SimulationIterator::startSimulation , 00007FF9DF963BDD (StarSolve): (filename not available): SimulationIterator::stopSimulation , 00007FF9F207CA6F (StarNeo): (filename not available): Controller::executeCommand , 00007FF9F207BB1C (StarNeo): (filename not available): Controller::processCommands , 00007FF9F0964779 (StarMachine): (filename not available): CommandController::scatterCommand , 00007FF9F0963453 (StarMachine): (filename not available): CommandController::processCommands , 00007FF9F0A335EA (StarMachine): (filename not available): Machine::startServerHost , 00007FF9F0A1F618 (StarMachine): (filename not available): Machine::main , ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF620C51EE0) , 00007FF620C51EE0 (star-ccm+): (filename not available): (function-name not available) , ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF620C5FEAF) , 00007FF620C5FEAF (star-ccm+): (filename not available): (function-name not available) , 00007FFA1EA87974 (KERNEL32): (filename not available): BaseThreadInitThunk , 00007FFA211AA271 (ntdll): (filename not available): RtlUserThreadStart ] error: Server Error expression: autoAllocateStorage(g) file: StoredVariable_t.h line: 131 Resetting cached Fe solid stress constraints and linear system. I'm not sure what information you need to help me. So please tell me what additional information I need to post. Thanks you in advance! Kind regards, Jeroen |
Did you manage to solve this one? Are you running an old version file?
