June 5, 2019, 04:32 |
View Fluid Film when Impingement
Rep Power: 6 |
Hi friends!
For the moment I am researching the impingment of a spray on a surface. When I select scalar scene Fluid Film Thickness nothing shows. Multiphase interaction between film and spray is on, shell region is created. Maybe is something about axis direction in the physiscs values of the shell region? Do you know what is happening? Please help |
June 6, 2019, 10:05 |
Rep Power: 6 |
I checked and particles seem to not be getting to the wall. Maye that is the reason why Fluid Film is not showing.
When I see Volume Fraction of Droplets, the are halfway between the injector and the surface and they don´t move. Could it be because of amount of sub-steps for the implicit unsteady solver? Hanging here and don´t know how to change the simulation to have it run properly. Thanks!! |
June 12, 2019, 12:45 |
Yogesh Nalam
Rep Power: 13 |
If they are not reaching till the surface from the injector, is it because the total physical time you are running is very less for the droplets to travel that distance?
June 12, 2019, 13:01 |
#4 | |
Rep Power: 6 |
I have calculated with a big number for substeps and the droplets still not reaching the wall. Thank you! |
June 12, 2019, 13:07 |
Yogesh Nalam
Rep Power: 13 |
In stopping criteria, change the 'Maximum Physical Time' or ' Maximum Steps'.
If this maximum physical time is sufficient for the velocity of droplets and the distance you want them to travel, may be the Maximium Steps is stopping the simulation. You can then increase maximum steps. |
[Other] conformed FSI mesh for unstructured fluid region | ashish.svm | OpenFOAM Meshing & Mesh Conversion | 10 | August 2, 2019 08:40 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Multiphase heat transfer | pkladisios | CFX | 8 | June 7, 2016 01:41 |
Post processor - how to view only specific part water by 'age of fluid' etc | s.petley | CFX | 1 | August 20, 2015 18:20 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
