June 21, 2019, 06:40 |
Streamlines vs moving reference frame
Rep Power: 6 |
Hi all
I have 3 regions in my axial fan simulation model. I used a moving reference plane for my rotating fan. Air is represented in the region of the fan (the middle region of the 3 present). I don't like the way streamlines appear in the fan region though. I've been told that there is a way to solve this issue but I don't know how to do that. Can anyone help me? Cheers |
June 21, 2019, 09:54 |
Matt
Rep Power: 17 |
You will have to be more specific about what you want to change.
June 21, 2019, 10:04 |
Rep Power: 6 |
June 21, 2019, 10:06 |
Matt
Rep Power: 17 |
Perhaps I misunderstand, but I see streamlines inside the fan region. Are they not what you expected?
June 21, 2019, 10:07 |
Matt
Rep Power: 17 |
Can you take a screencapture of your derived parts setup? (prtscn would be prefered over a photo, btw.)
June 21, 2019, 10:08 |
#6 | |
Rep Power: 6 |
I expected to see them more in circles than what I got. I thought it was due to the moving reference frame solution I used for the fan the fact that they barely develop inside the fan region. |
June 21, 2019, 10:14 |
Matt
Rep Power: 17 |
I would expect to see them change direction, but not necessarily swirl around within the fan region. The streamlines coming out of the back have obvious swirl.
Now that being said, you know what you are modeling better than I. If you have another reference or something you are comparing to that is similar and shows this behavior, then there might be something that needs to change. |
June 21, 2019, 10:27 |
Matt
Rep Power: 17 |
It does look like not all your streamlines are showing up on the other side. You might try adjusting the max propagation/steps in derived part > streamline> integrator.
June 26, 2019, 08:51 |
#9 |
Joern Beilke
Rep Power: 20 |
The trick is to create a new vector field function for the velocity which takes the absolure velocity in the fixed region and the relative velocity for the impeller.
Single moving reference frame vs Multiple reference frame for Wind Turbine CFD | mrswordf1sh | FLUENT | 4 | January 25, 2020 08:43 |
interFoam with moving reference frame | Martin_K_lalelu | OpenFOAM Running, Solving & CFD | 0 | November 4, 2014 02:41 |
moving mesh vs moving reference frame | nikolaous | FLUENT | 0 | August 1, 2012 18:46 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
