HerrOlsson |
July 5, 2019 08:47 |
Macro problem: export specific monitors
I'm trying to export some of my monitors from my simulation to a csv file using a macro (I have A LOT of monitors, so I have to use a macro).
I want to export only the monitors which has "Force" in their name, and "time step" as trigger. My problem is that I can't find out how to write the line for filtering out the monitors I want. I can filter out the ones with "Force" in the name, no problem. But I don't know how to filter on trigger type.
My code is as below:
package macro;
import java.util.*;
import star.common.*;
import star.base.neo.*;
import star.base.report.*;
public class solutionDataExport extends StarMacro {
public void execute() {
execute0();
private void execute0() {
Simulation simulation_0 =
getActiveSimulation();
// Collect all monitors
Collection<Monitor> monitorReports = simulation_0.getMonitorManager().getMonitors();
// Create an empty vector to which the monitors will be added
Vector monitorsVector = new NeoObjectVector(new Object[] {});
// Add monitors with "Force" in name and trigger type time step to vector
for (Iterator<Monitor> iterator = monitorReports.iterator(); iterator.hasNext();) {
Monitor thisMonitor = iterator.next();
if (thisMonitor.getPresentationName().contains("Force") && ???){
monitorsVector.add(thisMonitor);
// Export csv-file
simulation_0.getMonitorManager().export("./simulationData.csv", ",", monitorsVector);
In other words, with what should I replace ??? in line 29 of the code to make it work as intended?
Thanks in advance!
