Aerodynamic heating distribution around a blunt body |
July 14, 2019, 07:48 |
Stan
Rep Power: 9 |
Hi everyone,
i am simulating steady state aerodynamic heating distribution around a blunt body at M=2. (wall temperature is 300 K and air is ideal gas, turbulence model is SST K-W) Effect of Y+ on the heat flux distribution is attached. I see that Y+ should be around 1 or higher than 30. (in all of the simulations all y+ wall treatment is used). What are your comments? thank you. What about if y+ is lie between 5 and 30.? |
July 14, 2019, 14:40 |
Rep Power: 24 |
What about the rest of the mesh? Would you consider the resolution of the near-wall mesh outside of the first cell for these cases equivalent?
July 14, 2019, 16:26 |
Stan
Rep Power: 9 |
hi, sample mesh is attached. figures are extracted for conical side. thank you.
Blunt Body Problem | Iqrar.Raza | Main CFD Forum | 0 | April 27, 2016 01:04 |
BC for measuring force on blunt body | letthe | OpenFOAM Pre-Processing | 4 | December 9, 2013 18:20 |
Hypersonic flow over a blunt body | navu | Main CFD Forum | 1 | May 3, 2013 03:19 |
Where can find airfoil data with pressure distribution or aerodynamic data | Ahlo | Main CFD Forum | 5 | January 12, 1999 22:45 |
Aerodynamic Heating | J. Julia | Main CFD Forum | 1 | August 9, 1998 12:10 |
