July 23, 2019, 20:23 |
Diverge issue
Ian
Rep Power: 6 |
Hi everyone,
I’m new to star-ccm+ and I really need someone to help me at this point. After watching tutorials on YouTube and reading materials from google, I figured out most of my project and I got a good residual plot until something happened at interaction 250. Here’s what I’ve done: I repaired surface and there’s no piercing. I set up auto mesh and surface control all different regions. I did mesh diagnostic and removed bad cells. Cell quality remediation was turned on as well. My project is a double piped heat exchanger with hot water in the inner tube and cold air in the annulus. I set velocity inlet for annulus air and mass flow inlet for tube water. Both outlets were set to pressure outlet. I got a nice temperature and velocity contour before residual went sky high. After iteration 250, the residual went up to 1e4 and I stopped the algorithm. Can someone help me identify the problem here? I’ve tried lower the URF but it didn’t seem to work. I really don’t know what else to do. Btw, advancing prism layer mesh was used for both fluid regions and I assumed the boundary layer thickness was 1mm. |
July 23, 2019, 20:53 |
Rep Power: 7 |
I don’t have many knowledge in the software, for the mesh you can use mesh sensitivity to assure that your mesh is ok. For the divergent it may due the back flow. If you have a fluid domain you may try to make it larger I don’t know if this would be helpful.
July 23, 2019, 21:07 |
Ian
Rep Power: 6 |
Yes I think it caused by reversed flow since at interation 251 it appeared a lot reversed flow in air. How can I fix this reversed flow issue without changing the geometry? What do you mean by make it larger? Since I need to verify this CFD model with an experiment set up, I can't just change the model.
July 24, 2019, 04:26 |
Rep Power: 7 |
How did you add the fluid domain of air?.
July 24, 2019, 05:40 |
Ian
Rep Power: 6 |
August 7, 2019, 01:37 |
Steve
Rep Power: 8 |
Diverge problem is quite complecated.. It is very hard to give you any advice about this kind of thread. Sometime mesh problem is right, but sometimes are not.
Check what factor diverged in your residual first |
August 12, 2019, 13:11 |
Suggestion
RKE
Good Morning!
The description you provide suggests to me that your problem may be due to numerical instability occurring at some point where the velocity field changes rapidly (say at a turn, flowing past a baffle, etc.). That has happened to me when modeling agitator blades as the pass in front of a baffle in a stirred tank. I have been able to correct that by specifying relaxation factor ramps (i. e., progressively changing relaxation factors) for the various solvers. Maybe some variation of these adjusments could be of help to you. |
August 13, 2019, 17:02 |
#8 | |
Ian
Rep Power: 6 |
August 13, 2019, 19:22 |
Suggestion
RKE
Yes, I suggest using under-relaxation in the solvers. The system provides some initial ramp settings to try first.
residual |
Issue on zeroGradient BC for system rotation | magnushaese | OpenFOAM Running, Solving & CFD | 2 | January 28, 2022 13:43 |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Prism Layer - Core Mesh Boundary Issue | InfernoxCJC | STAR-CCM+ | 7 | November 21, 2017 15:46 |
foamToTecplot360 issue with multiregion solvers | manuc | OpenFOAM Post-Processing | 2 | November 21, 2016 13:51 |
Pressure boundary condition issue | Vijay | FLUENT | 0 | April 6, 2012 13:35 |
