July 23, 2019, 21:10 |
Boolean: Subtract error
James
Rep Power: 6 |
Hi all
I'm a beginner to Star-CCM+. I'd like to subtract my building (imported CAD model) and block but somehow it showed a message "Feature execution failed. SubtractBodies 1 : Subtraction would produce a non-manifold body". I just don't know what to do and I tried to fix my geometry in AutoCAD but it still didn't work. Can anyone give me some advice, please? 1.jpg Thank you |
July 24, 2019, 04:28 |
#2 | |
Check every body if it's fully closed manifold. Right click on every body and check for errors. If bodies have free edges and non-manifold edges and vertices then it is most probable that Boolean operations wont work. Hope this helps. |
July 24, 2019, 09:17 |
James
Rep Power: 6 |
Hi Ashok
Thank you for your advice. I have checked every body and couldn't find any error. When I tried substracting one by one, it worked. But when I substracted all together, I still got the same problem. However, I think I have solved the problem. I deleted some part of the bodies and it seemed to work. Thank you |
July 25, 2019, 10:22 |
Chaotic Water
Rep Power: 17 |
Try to move the object down and to subtract then - the problem might arise at the very bottom, that happens sometimes.
Another possible reason - input bodies are ok, but the result os subtraction is non-manifold like in the image: cubes are valid, but trying to subtract small cubes from the big one will result in error. |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
