Underprediction of Lift Coefficient-NACA0012
Like Tree4Likes
  • 2 Post By fluid23
  • 2 Post By fluid23
Old   September 13, 2019, 00:35
Default Underprediction of Lift Coefficient-NACA0012
shashankshankar is on a distinguished road
1. I have been trying to estimate CL and CD of NACA0012 airfoil. I am constantly getting an underprediction of CL by around 19%. The Reynolds number I am working on is 4.0E5. Details of the setup are as follows:-
(a) 3D Steady in water
(b) Polyhderal and Prismlayer mesher
(c) SST-menter K-w turbulence model. Wall Y+ after simulation is attached.
2. I am unable to understand what I am missing. Is it the mesh? The number of cells is around 1.4 million.
3. Convergence happens without any issues. Further, in SST Menter-K-w model, do we need to activate the low Re damping factor for this case? The starccm manual says only for transitional flows that action needs to be undertakenPrism Layer.jpg
shashankshankar is offline   Reply With Quote
Old   September 13, 2019, 09:26
Matt
fluid23 is on a distinguished road
your mesh is definitely not appropriate. look into wake refinement and conduct a mesh dependency study before determining that your converged result is the best you can do.
shashankshankar and cwl like this.
fluid23 is offline   Reply With Quote
Old   September 14, 2019, 05:07
Default Wake Refinement
Hello Matt,
1. Thank you very much for your suggestion.
2. Since the polyhedral meshing model doesn't have a wake refinement option, I incorporated a volumetric control. However, the drag result looks nice but CL is still being underpredicted.
3. I have set the extents of volumetric control based on the scalar view of velocity. Is there anything else I should incorporate in such cases?
Old   September 16, 2019, 09:03
Matt
The polyhedral mesher absolutely does have wake refinement options. A volumetric control is probably not the best way to approach that. Refer to the Star-CCM help files:
Pre-Processing > Meshing > Custom Mesh Controls > Mesh Refinement in a Wake
After that, make sure to do a mesh dependency study. Once you are confident that your result is independent of the spatial discritezation (i.e. your mesh), then you can assess whether your values are 'correct'.
Old   September 16, 2019, 14:52
cwl
Chaotic Water
cwl is on a distinguished road
You also can a Table-based Mesh Refinement.
cwl is offline   Reply With Quote
Old   November 13, 2019, 18:23
Chris
Chris2337 is on a distinguished road
The polyhedral only has wake refinement in parts-based meshing, so if you're using region-based meshing, like you would for the trimmer 2D, then switch to parts-based.
Chris2337 is offline   Reply With Quote
Old   November 14, 2019, 13:38
Paul Hancock
Paulh is on a distinguished road
Adaptive mesh refinement should be WAY easier than it is in CCM+, but . . . .
Consider taking a look at the STEVE article I'm hyperlinking below. It might give you some ideas on how to tweak your mesh to get the best predicted lift you can: https://thesteveportal.plm.automatio...pturing-shocks
Paulh is offline   Reply With Quote
Old   November 14, 2019, 13:46
cwl
Chaotic Water
How can it be "WAY easier"? - It consists of as few steps as possible:
1) Define where, why (∇P, ∇T, Turbulent Viscosity Ratio etc) and how the mesh should be refined via Field Function.
2) Extract Field Function to a table.
3) Mesh according to the table.
Since not everyone has constant access to the Steve Portal - here is a video on youtube:
Table Based Refinement in STAR-CCM+
starccm+ naca0012 mesh
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 06:04
CFX/Fluent- Underprediction of Lift Coeffcient in 2D Airfoil Simulation DanielBarreiro Main CFD Forum 4 September 2, 2021 02:16
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
