December 1, 2019, 15:08 |
Renaming surfaces in macro
Jack B
Rep Power: 7 |
Hi all,
I tried looking around for a previous post on this issue but I couldn't find anything. I have recorded a macro in Star-CCM+. In this macro I create a block, split it by patch and rename surfaces (ie. Inlet, Outlet, etc.). I see in the macro that each surface is given a specific ID number. The issue arises when I run the macro again, the surfaces are given different ID numbers every time a new Star-CCM+ file is created so the Macro can not rename them as it does not find them. Is there any way to rename surfaces without using this ID number or is there a way to make sure that the ID number is the same every time? Thanks in advance, Jack |
December 1, 2019, 19:39 |
#2 | |
Chaotic Water
Rep Power: 17 |
To be honest - I doubt that.
I remember some macros from macrohut that could do similar things - but that was long ago and lots of those capabilities are now implemented into Star. Quote:
I'm pretty sure that your problem can be solved in much easier way. Can you please descibe it more detailed? |
December 2, 2019, 17:36 |
Sebastian Engel
Rep Power: 20 |
Hi Jack,
yes you can, but it is likely less convenient. are you creating the box manually by sketch, or are you using a box primitive? If you use the latter you get methods to get the top and buttom surfaces easily. See the example below. But i assume you need settings for the sides as well? Anyways, you also can iterate through the list of faces. If you create just a box, the order and orientation will always be the same, and you might just sequentially set the names. For arbitrary sketch-based bodies, this should work quite similar. Inspect the example below where the collection of faces is created. You do not need to know the names or ids to get the collection. (you can use similar methods to get a collection of bodies). For more complex geometries, you might need to compare some additional properties. The loop has some additional lines Or, you pick faces by location - inspect the end of the script. This approach might be most versatile, if you can compute coordinates where your surfaces are, and when they are not too small and close to each other. best regards, Sebastian Code:
import java.util.*; import star.cadmodeler.*; import star.common.*; import star.base.neo.*; import star.vis.*; public class box extends StarMacro { public void execute() { Simulation simulation_0 = getActiveSimulation(); // Start making CAD Scene scene_0 = simulation_0.getSceneManager().createScene("3D-CAD View"); scene_0.initializeAndWait(); CadModel cadModel_0 = simulation_0.get(SolidModelManager.class).createSolidModel(scene_0); scene_0.open(); scene_0.setAdvancedRenderingEnabled(false); // SceneUpdate sceneUpdate_0 = scene_0.getSceneUpdate(); Units units_0 = simulation_0.getUnitsManager().getPreferredUnits(new IntVector(new int[] {0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0})); LabCoordinateSystem labCoordinateSystem_0 = simulation_0.getCoordinateSystemManager().getLabCoordinateSystem(); // Prepare box feature BlockPrimitiveFeature blockPrimitiveFeature_0 = cadModel_0.getFeatureManager().createBlockPrimitiveFeature(); // Set the box center location blockPrimitiveFeature_0.setCoordinateSystem(labCoordinateSystem_0); CadModelCoordinate cadModelCoordinate_0 = blockPrimitiveFeature_0.getCenter(); cadModelCoordinate_0.setCoordinateSystem(labCoordinateSystem_0); cadModelCoordinate_0.setCoordinate(units_0, units_0, units_0, new DoubleVector(new double[] {0.0, 0.0, 0.0})); blockPrimitiveFeature_0.markFeatureForEdit(); // Set the dimensions of the block blockPrimitiveFeature_0.getLength().setValue(0.1); blockPrimitiveFeature_0.getWidth().setValue(0.2); blockPrimitiveFeature_0.getHeight().setValue(0.3); // Create the box cadModel_0.getFeatureManager().execute(blockPrimitiveFeature_0); // rename patches Face face_0 = ((Face) blockPrimitiveFeature_0.getTopFace()); cadModel_0.setFaceNameAttributes(new NeoObjectVector(new Object[] {face_0}), "inlet"); Face face_1 = ((Face) blockPrimitiveFeature_0.getBottomFace()); cadModel_0.setFaceNameAttributes(new NeoObjectVector(new Object[] {face_1}), "outlet"); // Probably what you mentioned, faces by id Face face_4 = ((Face) blockPrimitiveFeature_0.getSideFace("1")); cadModel_0.setFaceNameAttributes(new NeoObjectVector(new Object[] {face_4}), "wall"); // get all faces star.cadmodeler.Body cadmodelerBody_1 = ((star.cadmodeler.Body) blockPrimitiveFeature_0.getBody()); Collection<Face> faces = cadmodelerBody_1.getFaceManager().getFaces(); for(Face face : faces) { // face names simulation_0.println(face.getPresentationName()); // extracting properties from face NeoProperty properties = cadmodelerBody_1.getFaceManager().getFaceProperties(new Vector<Face>(Arrays.asList(face))); simulation_0.println(properties); //get Face normal Vector<Double> normalVector =properties.getNeoProperty(String.valueOf(face.getEntityId())).getDoubleVector("Normal"); simulation_0.println(normalVector); } // Get Face by Location double[] picLocation = new double[]{-0.05, 0.0, 0.2}; Face faceByLoc = cadModel_0.getFaceByLocation(cadmodelerBody_1,new DoubleVector(picLocation)); simulation_0.println("Near " + Arrays.toString(picLocation) + " found Face: " + faceByLoc.getPresentationName()); // Renaming found surface cadModel_0.setFaceNameAttributes(new NeoObjectVector(new Object[] {faceByLoc }), "FaceByLocation"); // Finish CAD simulation_0.get(SolidModelManager.class).endEditCadModel(cadModel_0); simulation_0.getSceneManager().deleteScenes(new NeoObjectVector(new Object[] {scene_0})); } } |
Display Modes | |
fvOptions | npatricia | OpenFOAM | 6 | May 23, 2018 05:21 |
NURBS surfaces on a wing | frossi | CFX | 5 | February 5, 2017 15:27 |
timestep extraction for macro | manuc | Tecplot | 0 | August 10, 2016 12:20 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Macro problem | cfddummy | Siemens | 1 | April 9, 2007 12:37 |
