DEM Particles protruding through walls
Old   December 21, 2019, 18:53
Default DEM Particles protruding through walls
Jaymes
connor.dio12 is on a distinguished road
Hello all,
I am currently trying to model a randomly packed bed geometry, and am using Star's DEM tools to generate the particles. Everything works just fine until I need to create geometry parts for each sphere. Seen in the picture below, spheres are protruding through my wall surface (even before transforming them into geometry parts), and this is causing me to be unable to mesh correctly later on down the line.
[IMG] https://imgur.com/a/EZLj3LB [/IMG]
I've gone through the tutorials, plus followed some other videos online, and have yet to find an answer to this problem. My mesh size for the surface is larger than my sphere size, so there shouldn't be a problem between the sphere/wall interaction.
Thanks!
connor.dio12 is offline   Reply With Quote
Old   March 2, 2023, 10:29
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Originally Posted by connor.dio12 View Post
Hello all,
Thanks!
This is just a guess but your timestep might be too big. This sounds like the particles will check their vicinity for (possible) collisions (wall or each other) when a timestep is calculated but not in between. This would mean that particles are free to pass through walls while they travel a long time between timesteps.
Mahmoud Abbaszadeh is offline   Reply With Quote
Cross section pipe with DEM particles jeroendemto STAR-CCM+ 1 December 7, 2018 07:29
Jet in DEM modeling huangdf STAR-CCM+ 0 December 7, 2018 00:39
Two-Way coupled DEM with heat transfer - Which is good? - disscus now minhbaba Main CFD Forum 0 November 30, 2018 23:50
dsmcFoam - micro-hole limiting the number of dsmc particles Araist OpenFOAM Running, Solving & CFD 0 June 25, 2015 06:50
particles aren't moving with DEM model czhao86 FLUENT 0 December 4, 2013 14:46
