Design Parameter use in Field Function Reference value?
Old   January 14, 2020, 14:41
Default Design Parameter use in Field Function Reference value?
Chris Bailey
NotOsborneReynolds is on a distinguished road
Is there some trick to using Design Parameters in, for example, the Reference Length input to the Nusselt Number field function? I'm using my ${WallTemperature} global Parameter for its Reference Temperature, but don't seem to be able to do the same thing with my $PlateSpacing Design Parameter for its Reference Length. I've tried adding curly braces {} but that's not it.
Maybe Design Parameters can only be used as CAD dimensions, and not elsewhere?
My workaround is that I created a Design Parameter named PlateSpacing and then a global Parameter named PlateSpacingCopy, and I keep track of them on my own, but it's klunky.
Thank you!
NotOsborneReynolds is offline   Reply With Quote
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 00:58
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Compiling new Solver with wmake lin123 OpenFOAM 3 April 13, 2010 14:18
