Velocity inlet at a point.
Old   February 4, 2020, 03:43
Default Velocity inlet at a point.
Andrea
apara is on a distinguished road
Hi all,
I am relatively new to Star CCM+, and I am currently working on simulating fluid flow around a circular cylinder for a project I have. I want to add a velocity inlet at two particular points (Point A and Point B) on the cylinder in order to suppress vortex shedding in the wake of the cylinder. So in total, I will have 3 velocity inlets. One which is part of the boundary wall upstream of the cylinder, and the remaining two at points A and B. Not sure if this is possible.
Thanks.
apara is offline   Reply With Quote
Old   February 4, 2020, 09:59
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
A velocity inlet at a point is not possible. You need to think in terms of volumes and surfaces. A "point" does not exist in this landscape.
You can apply a momentum source at a single volume. You can apply a velocity inlet on a single face. But points don't exist.
Pressure problems with inlet variable velocity jaimesdiegop CFX 2 September 1, 2016 03:31
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow mohibanwar Fluent UDF and Scheme Programming 10 May 18, 2015 11:34
Setting Density for Velocity Inlet Face arkie87 FLUENT 0 November 7, 2012 16:15
[swak4Foam] groovyBC, coupling inlet with velocity at specific point location olivierG OpenFOAM Community Contributions 6 June 23, 2012 09:44
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
