[meshing] Invalid ID insterted into subset
Hi all,
I am attempting to produce a mesh of a multi-body system. The surface remesh works, following which, the Tet mesher gives the following error:
Inserting invalid id into subset: (invalid)
stack trace:
libMKSurfaceView.so: MKSurfaceView::SurfaceBase::newFace(MKCore::Id, int, MKCore::Id, bool
libMKSurfaceView.so: MKSurfaceView::AddFv<MKSurfaceView::TriangleBase>: :newFace(MKCore::Id, MKCore::ConstFaceVertices const&, int, MKCore::Id, bool
libMKSurfaceView.so(+0x8e6e9
libMKSurfaceView.so: MKSurfaceView::appendSurface(MKSurfaceView::Triang leBase const&, MKSurfaceView::TriangleFv&, MKCore::Subset const&, std::map<int, int, std::less<int>, std::allocator<std::pair<int const, int> > > const*
libStarMeshing.so: SurfaceMeshBase::appendMesh(SurfaceMeshBase const&, MKCore::Subset const&, MeshTypeMap const&, MKCore::IdHashMap<MKCore::Id>*, bool, MKCore::IdHashMap<MKCore::Id>*, MKCore::IdHashMap<MKCore::Id>*
libStarMeshing.so: ShellSurfaceMesh::append(ShellSurfaceMesh const&, GeometryPart const&, MeshTypeMap&, Cad::CadSet<Cad::Body> const*, MKCore::IdHashMap<MKCore::Id>*, MKCore::IdHashMap<MKCore::Id>*, bool
libStarMeshing.so: ShellSurfaceMesh::append(ShellSurfaceMesh const&, GeometryPart const&, MeshTypeMap&, Cad::CadSet<Cad::Body> const*, MKCore::IdHashMap<MKCore::Id>*, bool
libStarMeshing.so: ShellSurfaceMesh::append(ShellSurfaceMesh const&, GeometryPart const&, bool
libStarSolidMesher.so: ThinAutoMesher::storeThinFacetypes(ShellSurfaceMes h const&
libStarSolidMesher.so(_ZN14ThinAutoMesher4initEPSt 6vectorIP8MeshPartSaIS2_EEPKSt3setIjSt4lessIjESaIj EERN9Dt3Mesher10Dt3Options
libStarDelaunayMesher.so(_ZN18DelaunayAutoMesher15 executeInternalERSt6vectorIP8MeshPartSaIS2_EERK16S hellSurfaceMeshRN6MKCore13
libStarDelaunayMesher.so(_ZN18DelaunayAutoMesher7e xecuteERSt6vectorIP8MeshPartSaIS2_EERK16ShellSurfa ceMeshRN6MKCore13Interface
libStarDualMesher.so(_ZN14DualAutoMesher7executeER St6vectorIP8MeshPartSaIS2_EERK16ShellSurfaceMeshRN 6MKCore13InterfaceMapsERKS
libStarDualMesher.so(_ZN14DualAutoMesher27meshPart ConformallySpecificERSt6vectorIP8MeshPartSaIS2_EER K16ShellSurfaceMeshRN6MKCo
libMeshingPipeline.so: VolumeAutoMesher::meshPartConformally(std::vector< MeshPart*, std::allocator<MeshPart*> >&, ShellSurfaceMesh&, ShellSurfaceMesh*&, PatchTypeMapper&
libMeshingPipeline.so: AutoMeshPipeline::meshPartsConformally(std::vector <MeshPart*, std::allocator<MeshPart*> >&, std::vector<MesherBase*, std::allocator<MesherBase*> > const&
libMeshingPipeline.so: AutoMeshOperation::executeSpecific(
libMeshingPipeline.so: MeshOperation::execute(
libMeshingPipeline.so(+0x2825db
libStarNeo.so: Controller::executeCommand(Command&, Properties const&, Properties&
libStarNeo.so: Controller::processCommands(
libStarMachine.so: CommandController::SerialMasterCommandLoop::start(
libStarMachine.so: CommandController::processCommands(
libStarMachine.so: Machine::startServerHost(int, char**, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, unsigned int, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_strin g<char, std::char_traits<char>, std::allocator<char> > const, unsigned int> > >&
libStarMachine.so: Machine::main(int, char**
Invalid id inserted into Subset!
Command: ExecuteMeshOperation
error: Server Error
Loading/configuring connectivity (old|new partitions: 1|1)
Configuring finished
Nobody in my immediate group of colleagues has seen this error before. Anyone who could suggest why this may occur?
No pierced faces, suspicious proximity, free or manifold edges are present in my split geometry (either root or remeshed)
Here's my approach: Import CAD -> Combine all parts -> Imprint all necessary faces & other surface repair -> Split by topology -> Create regions (individual fluid regions & multi-component solid regions) -> Mesh
