Freeze Wall Distance Solver for Rotorcraft Simulation
Old   June 21, 2020, 10:58
Default Freeze Wall Distance Solver for Rotorcraft Simulation
Chris
Chris2337 is on a distinguished road
Hey everyone,
I'm running a rotorcraft simulation using an overset mesh approach (mesh around each blade overset with a background) and it's taking a while to run. The subiterations are what I would expect but the hole cutting, interpolation, and wall distance calculation just take longer than I think it should, which makes the whole thing long. To combat this I'm thinking of freezing the wall distance solver since after the first iteration I think the distances for the blade meshes should be the same and the distances in the background mesh should be far enough from any surface that they dont make a difference.
I'm just looking for any thoughts to speed up the process for when the blades change position, and if freezing the wall distance solver seems like a bad idea.
Thanks,
Chris
Chris2337 is offline   Reply With Quote
Old   June 23, 2020, 09:36
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
The wall distance solver is super duper fast and shouldn't be slowing down your calculation much. If it is, that hints that something else is causing a problem.
Old   June 24, 2020, 13:40
Chris
Okay, that's my notion from doing aircraft with large meshes and it runs quickly. If you've done anything similar with overset do you have any recommendations? It says "Calculating Wall Distance" but then usually colon and something else about interpolation so it is doing something regarding the overset calculations rather than just calculating the wall distance.
It is just annoying because the update takes about as long, or longer, than running the iterations, which I feel like should not be the case. I see in the Steve Portal they talk about using multiple interfaces to expedite the process but I'm not sure that's possible with overset interface.
Divergence in AMG solver! marina FLUENT 19 March 22, 2018 09:00
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 32 February 7, 2018 08:26
Solver Yplus of Automatic wall treatment justjhy CFX 2 May 4, 2013 07:19
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Bug in wall distance calculation david OpenFOAM Bugs 3 March 15, 2011 09:32
