Field function for velocity inlet
Old   July 11, 2020, 02:43
Default Field function for velocity inlet
David712 is on a distinguished road
I encountered such a problem, I have already simulated a steady flow in ccm+ and I can export the values at the outlet like velocity, pressure,etc. Now I want to put the exported values as velocity input in another flow field, how to realize this process? I have tried using the table to set the initial flow field, but fail to realize.
David712 is offline   Reply With Quote
Old   July 11, 2020, 03:21
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
1. Export the table
2. Import the table
3. Use a data mapper to map the table onto your boundary, creating a mapped field function
4. Use the mapped field function as the BC
Old   July 11, 2020, 21:14
Originally Posted by LuckyTran View Post
1. Export the table
2. Import the table
Thank you very much. It works.
star ccm+;field function
Varying Pressure Outlet with Field Function t8fanning STAR-CCM+ 14 November 1, 2017 10:39
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
velocity field function at the inlet of T junction abdoganawa STAR-CCM+ 0 February 4, 2015 00:28
field function and tables for inlet profile natalie26 STAR-CCM+ 3 March 5, 2013 02:54
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
